wwenze
- Dec 2, 2002
TDA1543 isn't a new name in audio; rather, it has already been discontinued for eons, Philips Semiconductor kind of died, and NXP doesn't even store the datasheet.
This IC, along with its expensive brother TDA1541, are known for being non-oversampling (a.k.a. NOS), or multibit, DACs. Or "it's not a yucky sigma-delta DAC". But while TDA1541 is very expensive and usually found only in high-end (sic) implementations, "TDA1543" is a DIP-8 chip that is very affordable and easily implementable and can be found in many cheaper products, often with multiple chips in parallel to... I dunno, improve the performance?
(You'll find out why there are inverted commas on TDA1543 later.)
Why NOS DAC?
Many people say many different things. Detailed lengthy articles can be summoned at will by Google.
What I can remember are:
- Non-oversampling. If the input says to output a voltage of 0.5, it outputs a 0.5. As opposed to an oversampling DAC, which outputs a 1.0 for 50% of the time by turning on and off.
- Oversampling DACs require a filter to convert that 1.0 @ 50% into a 0.5, and this introduces ringing in the process. Pre-ringing in particular seems to be the fault of all things modern. NOS DACs don't require a filter since the output voltage is, just, there. Unless you count the optional LPF to smooth out the aliasing, which still doesn't cause pre-ringing.
- Sounds more natural, tube-like, yadda yadda.
Why the Muse Mini TDA1543x4 DAC?
Because it's cheap. Like seriously, it costs 200RMB on Taobao, and another 50RMB for international shipping.
There are other sigma-delta-based DACs that are even cheaper, and possibly perform even better, but I got this because it is NOS. I already have good sigma-delta DACs, this NOS DAC is for education purposes, to listen to the NOS sound that is oh so wonderful.
And also this particular model has been out in the market for pretty long and many people have heard of it / own it / have talked about it / modded it / reviewed it - there's a 65-page thread on head-fi, which only adds to the fun later.
Why NOS DAC?
