After consideration .. I decided to get the Bolt Red instead cos i find the part that i have chose is around the same price but only motherboard w cpu + gpu which cost around 1k so might as well change everything new.
Here is what I come out with:
Warranty (Desktop) : 3 Years Parts Warranty (1st Year ONSITE)
Chassis : Bolt : Bolt White Edition Tempered Glass
CPU (Bolt) : AMD RYZEN 5 2600X 4.2 GHZ (6 Core 12 Threads)
DESKTOP MOTHERBOARD (BOLT, ZEAL) : X370M Motherboard (AMD)
Memory (RAM) : 16GB (8GB x 2) DDR4 3200mhz KLEVV BOLT X Low Latency RAM
Graphics Cards (Bolt Red) : AMD RX580 8GB GDDDR5 Overclocked Edition (LIMITED ONE TIME OFFER!!!)
Thermal Compound : Stock Thermal Compound
CPU Cooling System (Desktop) : AIR COOLING : CRYORIG C7 Low Profile CPU Cooler
Solid State Drive, Bolt : 240GB SSD
Without:
1TB HDD (cos i alrd have it)
Total $1,221
Do i need a better cooler? or just stick to the normal INTEL/AMD stock cooling fan solution?
Both almost same, buy the cheaper one or whichever will make you feel better.
