Need help building my first gaming rig!
Caramallows
Hi! As titled, this will be my first gaming rig.
My budget is around 1.3~1.5k.
Mainly used for casual gaming such as Dota 2, Final Fantasy Type-0, L4D2 and running multiple programs in the background (Eg. Songs, browser, games,etc.)
I picked a few components already but am still unsure of several of my picks and remaining components.
CPU: Intel i5-4590
MB: Asrock H97M-ITX/ac (I'm unsure for this one, should i get a Wireless PCI-E?)
RAM: G.Skill RIPJAWS-X 1600MHZ 8GB (4GB x2) CL9
GPU: (Need help)
SSD: Samsung SSD 850 EVO 250GB
HDD: Western Digital Blue 1TB
PSU: FSP Aurum S 500W [80 Plus Gold]
CASE: Sharkoon T28 [Blue]
MONITOR: (Need help)
Do i need aftermarket coolers or will stock coolers be enough?
I'm not sure of the prices if they're within my budget as several components differ shops to shops.
Additionally is there anything i should take note of? Any help is greatly appreciated! Thanks in advance!
CPU: Intel i5-4590
GPU: (Need help)
My recommendation for your new rig.
Teo En Ming
shadow84
Hyper 103 @ $68 is soooo :crazy:
Add $20 more can already upgrade to AIO... :s22:
And it is considered one of the lousiest cooler.
At least En Ming helped us in a way - Fuwell is the next chop carrot shop, learnt from cybermind ah?
MoneyFace =p
Yeah still remember have recommendation very long ago for like $30+ only...
Caramallows
Okay so i roughly put together this build on MyNeXTComOnline's website, i know some of the components can be gotten cheaper elsewhere but this is just a rough guideline for me atm.
CPU+MB: Intel i5-4590 + Asrock H97M-ITX/ac - $457
RAM: G.Skill RipjawsX 1600MHz 8GB(2x4GB) 9-9-9-24 - $122
GPU+PSU: MSI N750Ti TF 2GD5/OC (GeForce GTX 750Ti GAMING) + FSP Aurum S 500W [80 Plus Gold] - $ 334
SSD+HDD: Samsung SSD 850 EVO 250GB + WD Blue 1TB - $239
CASE: Sharkoon T28 [Red] - $89
MONITOR: AOC 23" i2367FH -$239
Total Cost: $1,504
Is this too much? Does something need to be changed? Please let me know! Open to all suggestions as i'm really new to this! Thanks!
zenniz
Why don't you drop the CPU to i5 4460, get H81 mobo and value ram then invest the remainder on a better graphic card like GTX960 or R9 280.
You get alot more better performance compared to your latest listed one.
If i would to choose GTX750Ti, i would go for i3 cpu instead to complement both cpu and gpu's performance.
origamii
Total Cost: $1,504
maybe you should change your processor and mobo
Goodshot
Seriosly change ur cpu+mobo to 4460+Asus H81M-A man , use the $110 go buy a better gfx ba , i see ur 750ti cannot game shitt
MoneyFace =p
CPU: Intel i5-4590
GPU: (Need help)
Full Blue-Black Themed PC
CPU+MB: Intel Core i5-4460 + ASRock B85M Pro4 @ $327
RAM: Kingston HyperX Fury DDR3-1600 CL9 8GB Dual Channel Kit [Blue] @ $95
GPU: Zotac GTX 960 2GB Twin Fan OC @ $295
SSD: Samsung SSD 850 EVO 250GB @ $162
HDD: Western Digital Blue 1TB @ $73
PSU: Super Flower Leadex Silver 550W [80 Plus Silver] @ $109
CASE: Sharkoon T28 [Blue] @ $73
OS: Microsoft Windows 8.1 Pro 64-bit Product Key [OEM] @ $33 (G2A)
Download ISO here.
And upgrade to Window 10 Pro for free thereafter. Save yourself $100.
WIFI: Intel Dual Band Wireless-AC 7260 + Bluetooth for Desktop [PCIe] @ $79 (Laser Distributor)
DSP: Dell P2314H 23" 1080p 60Hz W-LED [AH-IPS] @ $259** (COMEX 2015)
Total: $1505
Buy others from Tradepac, #05-18. Haggle for discounts!
*Price after Lazada MasterCard Monday 10% discount (Capped at $25)
**Priced based on PC Show 2015
MoneyFace =p
But do you really need WiFi or can connect to router via wired LAN cable? Any obstruction between PC location and your router?
origamii
CPU+MB: Intel Core i5-4460 + Asrock B85 Killer @ $342 (Tradepac)
RAM: Kingston HyperX Fury 8GB Dual Channel Kit @ $97 (Tradepac)
GPU +PSU: Gigabyte GTX 960 + Seasonic M12II 620w 80+ @ $418 (Tradepac)
SSD: Samsung SSD 850 EVO 250GB @ $162 (Tradepac)
HDD: Western Digital Blue 1TB @ $73 (Tradepac)
ODD: Samsung 24X CD/DVD Writer [OEM] @ $21
CASE: Sharkoon T28 @ $73+/-
OS: Microsoft Windows 8.1 Pro 64-bit Product Key [OEM] @ $33 (G2A.com)
Monitor : Dell S2340L @ $209 (Tradepac)
Total Cost :$1,428
You can try asking for $1350. No harm trying
You do not need aftermarket cooler since not doing overclocking.
With excess money get yourself a keyboard ,mouse and speaker .
