Hi, I am looking to purchase a laptop and would appreciate any advice/suggestion.
The main daily use would be for shows, emails and the usual social media activity. Photo editing and the occasional sound editing. I may want to try my hands at graphic design as well so that is part of the consideration.
I won't be carrying the laptop around much, so weight isn't that much of an issue here. Budget should hopefully stay in the $1.5k range or lower.
I went to Challenger and looked online a bit, and shortlisted the following:
1. Acer Aspire V Nitro VN7-592G-79WA
2. Asus Vivobook K501UX-DM079T
I saw the Aftershock brochure for Comex and wonder if I should consider their M-15 V2 Edition.
BEtween these three the difference are the graphics cards and also the HDD+SSD. Would it be better to have both of them or just one or the other?
Lastly, would the price/deals for laptops be better at Comex or would they not differ that much from buying online or at the physical stores?
Thanks!
Thanks!
