Hi all, just checking if anyone know which is the best way for me to connect Wii old cav cable to my samsung TV.
Well long story short, my samsung tv (cant rmb the model and is quite old one) does not have component port as its ext out to another cable to connect composite and av connect (susoect i might have thrown away) and im now on a delima on wheather to either one find a converter for wii or a converter for my tv or souce for the component cable?
Here is my concern,
1) wii to hdmi seems feaslible to me since i have a few ports on my tv and hdmi cable to spare.
2) having a hdmi to converter to component port will it reduce the quality and screen size?
3) find the so call original/replacement cable for the componenet port for my tv?
1 and 3, i found both to have a cheaper/budget one but no 2 is a totally unknown to me and reuired me have ext power adapter from some of them which i dun have a lt of plug for it.
but would like to hear some opinion if anyone have tried the 1st one and it works with your Wii?
Here is my concern,
