Need help on rig!
singupingu
Wow man!
Thanks for taking the time off to curate such a detailed reply!
Just a few quick questions..
The small stuff like screws and washers, will they come with the case or I have to purchase them separately?
Do you suggest me getting the case and items then deciding on what small items to get?
As for the drivers and stuff, what are the main ones I should download?
Screws and everything are included with the casing. You just need your own screwdriver.
Just get everything we suggested here. Small items like ssd and hdd are standardized sizes. So they will all fit for sure.
Download everything under drivers section and install them. Make sure it's the exact model will do.
Sent from Overpowered Phone Mark III using GAGT
Psycholific
Dun stand on top of carpet can le. And before u touch ur components, touch your case to discharge urself. Play safe.
Ooo, okay!
This is a handy tip to know!
Any other tips that you think should be important for a first timer?
HAHA!
shadow84
When mounting mobo into case, best to lay flat the case and mount.
Also when screwing in, do in a criss-cross manner, ie top right, bottom left, top left, bottom right, other screws. Do not tighten each screw at start but wait till all svrews are in then u tighten. And dun over tighten as u might break the mobo. As long as you felt the initial 'tightness', it should be fine.
MianBaoFren
tmr got new qoo10 coupons. maybe u should hold off your purchases till then. if u need/want to, i can help u design a rig then.
potentially alot of savings. u could even squeeze in a gtx 1070...]
oh and u shld paste your final quote if u have one in mind. we can see what can be better balanced to suit your needs.
Psycholific
Alright!
I think I will look more into the drivers to ensure everything is smooth!
Thanks!
Psycholific
Is there a right way up for the mobo?
Or both ways also can?
And the manual will come with the case?
shadow84
refer to both case and motherboard manual.
If you lay case flat on the table/floor, it would be easier for u to mount.
Psycholific
cpu: i5 6500 @ 265 (after applying qoo10 $60 coupon) http://list.qoo10.sg/item/INTEL-ORIG...QUAD/471972177
mobo: gigabyte ga-h110m-ds2 @ 120
ram: kingston ddr4 8gb ram 2133mhz x 2 http://list.qoo10.sg/item/KINGSTON-K...tions=13384193
gpu: zotac gtx 1060 6gd amp @ 415 http://list.qoo10.sg/item/ZOTAC-ZOTA...CARD/480895587
psu: fsp 450w hexa plus @ 58
ssd: pny 240gb @ 102 http://list.qoo10.sg/item/LATEST-PNY...ANCE/464910883
hdd: 2tb
os: windows from reddit microsoft software swap @ 30
casing: most probably getting an ATX or MATX, maybe from qoo10 too
Is this enough to run games & video editing software at a rather quick pace?
Psycholific
Ahh.. Then if want to beautify my case, like put LED lights all, is it a standard way?
Or depending on case then need to identify?
