Need help with Asus PCE-N15
Peach Tea
Suspended
Hi Guys.
I just installed a new PC
Mobo Asrock H81-HDS
I boot to BIOS and set primary video card as onboard.
But if I plug in the Asus PCE N15 into PCIe 1 slot, PC boot up but no display. If I plug into PCIe slot 2. It's able to work.
Any advices?
Thanks in advance
trento
this card uses the shorter pci slot. the longer slot is for gpu. did u put a gpu in slot 1?
anyway, be wary of slow connection. not the card problem but driver issue.
Peach Tea
Suspended
I slot in the pci-e x16. So must use the pci-ex2 slot?
As for slow connection, you mean internet speed? If yes how to overcome this issue?
trento
i suppose so cos slot one is for gpu. i have the same mobo. slot 1 gpu and slot 2 (shorter one) network card.
yes, internet damn slow. issue is the Realtek network driver. u need to download that. refer to this thread
Asus pce-n15 not working - Wireless - Networking
do note if it works well then just leave it
