Need help with BSOD
User-name
Recently BSOD with error code 1033 this is what i received from the crash analysis
It also shows atikmpag.sys at the blue screen
Instant Online Crash Analysis, brought to you by OSR Open Systems Resources, Inc.
Show DivPrimary Analysis
Crash Dump Analysis provided by OSR Open Systems Resources, Inc. (OSR Homepage - OSR)
Online Crash Dump Analysis Service
See OSR Online - The Home Page for Windows Driver Developers for more information
Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 7601.18409.amd64fre.win7sp1_gdr.140303-2144
Machine Name:
Kernel base = 0xfffff800`02c1e000 PsLoadedModuleList = 0xfffff800`02e61890
Debug session time: Mon Jun 9 09:56:42.859 2014 (UTC - 4:00)
System Uptime: 0 days 7:23:26.671
* Bugcheck Analysis *
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)
This is a very common bugcheck. Usually the exception address pinpoints
the driver/function that caused the problem. Always note this address
as well as the link date of the driver/image that contains this address.
Some common problems are exception code 0x80000003. This means a hard
coded breakpoint or assertion was hit, but this system was booted
/NODEBUG. This is not supposed to happen as developers should never have
hardcoded breakpoints in retail code, but ...
If this happens, make sure a debugger gets connected, and the
system is booted /DEBUG. This will let us see why this breakpoint is
happening.
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff8800f3a1dbb, The address that the exception occurred at
Arg3: fffff88002ba7228, Exception Record Address
Arg4: fffff88002ba6a80, Context Record Address
Debugging Details:
TRIAGER: Could not open triage file : e:\dump_analysis\program\triage\modclass.ini, error 2
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at "0x%08lx" referenced memory at "0x%08lx". The memory could not be "%s".
FAULTING_IP:
atikmdag+c7dbb
fffff880`0f3a1dbb 488b83a8060000 mov rax,qword ptr [rbx+6A8h]
EXCEPTION_RECORD: fffff88002ba7228 -- (.exr 0xfffff88002ba7228)
ExceptionAddress: fffff8800f3a1dbb (atikmdag+0x00000000000c7dbb)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 0000000000000000
Parameter[1]: 00000000000006a8
Attempt to read from address 00000000000006a8
CONTEXT: fffff88002ba6a80 -- (.cxr 0xfffff88002ba6a80)
rax=0000000000000000 rbx=0000000000000000 rcx=0000000000000000
rdx=0000000000000000 rsi=0000000000690000 rdi=0000000000000002
rip=fffff8800f3a1dbb rsp=fffff88002ba7460 rbp=fffffa800a26d060
r8=0000000000000002 r9=000000f421030000 r10=0000000000000000
r11=fffff88002ba7690 r12=fffffa80096e6b40 r13=fffffa80095925c0
r14=fffffa800a627740 r15=fffff8800f2da000
iopl=0 nv up ei pl zr na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010246
atikmdag+0xc7dbb:
fffff880`0f3a1dbb 488b83a8060000 mov rax,qword ptr [rbx+6A8h] ds:002b:00000000`000006a8=????????????????
Resetting default scope
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: 0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at "0x%08lx" referenced memory at "0x%08lx". The memory could not be "%s".
EXCEPTION_PARAMETER1: 0000000000000000
EXCEPTION_PARAMETER2: 00000000000006a8
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002ecb100
GetUlongFromAddress: unable to read from fffff80002ecb1c0
00000000000006a8 Nonpaged pool
FOLLOWUP_IP:
atikmdag+c7dbb
BUGCHECK_STR: 0x7E
LAST_CONTROL_TRANSFER: from 0000000002b60000 to fffff8800f3a1dbb
STACK_TEXT:
fffff880`02ba7460 00000000`02b60000 : 00000000`02b68fff fffffa80`096e6b40 00000000`00000003 fffffa80`0a627740 : atikmdag+0xc7dbb
fffff880`02ba7468 00000000`02b68fff : fffffa80`096e6b40 00000000`00000003 fffffa80`0a627740 fffff880`0f402f6f : 0x2b60000
fffff880`02ba7470 fffffa80`096e6b40 : 00000000`00000003 fffffa80`0a627740 fffff880`0f402f6f 00000000`00000100 : 0x2b68fff
fffff880`02ba7478 00000000`00000003 : fffffa80`0a627740 fffff880`0f402f6f 00000000`00000100 fffffa80`0a0a3820 : 0xfffffa80`096e6b40
fffff880`02ba7480 fffffa80`0a627740 : fffff880`0f402f6f 00000000`00000100 fffffa80`0a0a3820 00000000`00000098 : 0x3
fffff880`02ba7488 fffff880`0f402f6f : 00000000`00000100 fffffa80`0a0a3820 00000000`00000098 000e2b5f`00000098 : 0xfffffa80`0a627740
fffff880`02ba7490 00000000`00000100 : fffffa80`0a0a3820 00000000`00000098 000e2b5f`00000098 00000000`00000000 : atikmdag+0x128f6f
fffff880`02ba7498 fffffa80`0a0a3820 : 00000000`00000098 000e2b5f`00000098 00000000`00000000 00000000`00000001 : 0x100
fffff880`02ba74a0 00000000`00000098 : 000e2b5f`00000098 00000000`00000000 00000000`00000001 00000000`ffffffff : 0xfffffa80`0a0a3820
fffff880`02ba74a8 000e2b5f`00000098 : 00000000`00000000 00000000`00000001 00000000`ffffffff fffff880`02ba7730 : 0x98
fffff880`02ba74b0 00000000`00000000 : 00000000`00000001 00000000`ffffffff fffff880`02ba7730 fffff880`02ba75e0 : 0xe2b5f`00000098
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: atikmdag+c7dbb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: atikmdag
IMAGE_NAME: atikmdag.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 53508a3c
STACK_COMMAND: .cxr 0xfffff88002ba6a80 ; kb
FAILURE_BUCKET_ID: X64_0x7E_atikmdag+c7dbb
Followup: MachineOwner
User-name
Fixed the problem. my motherboard bios version too old after flashing bios it does not have any more BSODs
