Need Help
seeker
Hi Forumers,
Can anyone help me solve this problem:
Notice the small square boxes on the left hand side under 4-Way Optimization,
they were actually English words there.
How do I change it back to English words instead of squares.
TIA
seeker
Hi ykgoh,
Thanks for the respond, on the other page of the Al Suite III some of the fonts are mixed with Chinese characters. Any idea why this happens.
TIA
ykgoh
I have no definite answer. However, some Windows users did report similar problem that occur irregularly, particularly with Asian fonts. So this may be due to a bug in Windows. I suspect sometimes when Windows do not shut down cleanly or with disk caching enabled, the font cache may become corrupted.
For me, my case was the Asian fonts were messed up, so file names with CJK characters showed up as square blocks in Windows Explorer.
If rebuilding the font cache doesn't work, maybe you can try reinstalling your software or repairing Windows. It might be using or depending on certain fonts installed in your system, which unfortunately could have been uninstalled? Reinstalling the required missing font may also help.
seeker
Problem solved, went to the PC shop and asked the tech guy there why there are small squares in the Al Suite 3 program and he told me to change the Language in Control Panel to display all non-Unicode support language to English. Tada!
Hope that anyone with this problem can share this info.
Thank you folks.
Cheers!
