Need help
grh_jj
Hi all, currently got a 1 year plus DIY CPU, recently keep giving me bsod and random restarts and hang at certain times. Any idea what's the issue?
royfrosty
Provide us the specs as much as possible and we can help you further.
This seems to be like multiple failures.
You can run memtest86 and see how it goes for the ram portion.
Run CrystalDiskinfo and check the health of the HDD or SSD.
Download HWMonitor and run Prime95 to check on CPU temp.
If there is a gpu
Try Furmark test.
grh_jj
If there is a gpu
Try Furmark test.
Ok can thanks for the prompt reply, will post the specs here tmr, and also run the checks as well
