Need recommendation for bumper re-spray
Nurse.Vijay
man i ruin my bumper again so i need another respray. think is i just sprayed few months back, entire bumper for 180 but quality not very good. i just gentle rub against some zinc roof like material and part of the paintwork cracked. if not can just polish off. now need to respray. any other workshop to intro?
CCCustom
If you're willing to pay for good quality, go to Phua Spray Painting at AMK Autopoint 4th storey next to Riverview. They were known for being subconned for Lexus colour change (back in the day, not sure though whether or not they still are), and they use Sikkens.
Nurse.Vijay
thanks. will take note.
i don't mind paying for quality. because i know for light knocks and dents wouldn't crack the paintwork. the very first time i langa the car with stock paintwork also never crack, somemore impact quite hard. even since a bit of rubbing will crack the whole paintwork. not sure is due to sand and spray or that [articular workshop.
CCCustom
The gold standard for car paint is Sikkens and DuPont. I wouldn't use any spray paint shop that doesn't use either brand.
ASM_HWZ
Try Kereta, I done my repair for my front bodykit with them. The price slightly ex. Boss William is friendly. You can whatapp him the damage, he will gave you the est damage you need to pay.
