Need some advice and help regarding graphics FPS issue...
OrdinaryMoon
Hi guys, I bought a PC at the start of july 2015.
- Intel I3 4160
- Asrock H81M HDS
- Kingston 1600 8Gb
- Toshiba 1Tb Harddisk
- Windows 8
- Zotac GTX nvidia 750 Ti 2GB
- FSP hexa 450w
So now about close to 2 months of using the PC. Recently i have been seeing a drop in FPS when i'm playing Dota2. It used to run at a steady 60 FPS but in the past 2 weeks i've seen it drop to 40+ during gameplay. What does it mean when the game FPS drops? It's only 2 months old... Is it the GFX card issue or some virus thats slowing down the PC? I've been told that dota2 is pretty low requirement so this set up should suffice for it. Could it be overheating? I've tried to feel the surface of my PC and it doesnt feel hot? I did not download any funny things,dont torrent at all either.
Any kind soul can advise me on what i should do to solve the issue? Sorry for asking a silly question here because i am clueless about IT stuffs.
L3g0la5
Hmmm. Can be quite a few things that might affect the FPS drop. Though honestly speaking, a drop from 60 fps to 40 fps should not impact your gameplay so much either. If it drops from 60 to below 30 then it would be very much noticeable.
That said, you can try seeing if your game is optimized. Update the gfx drivers. Nvidia does provide an optimization driver for their graphics card and it does support Dota 2 if I recall. Besides that you can check the following:
- Is your graphics card running at optimum efficieny? Try using a monitoring software to look at the heat its generating and everything. MSI Afterburner or such should be able to do so.
- Do a quick power supply calculation using a reliable website to get a rough estimate. See if your current PSU is sufficient to run your PC when its gaming on load.
- Check background processes running. You're using an i3 processor which I probably would not recommend for gaming (i5 at least is preferable). So see if you have any background processes running that can affect your gameplay. Take note that certain software like anti-virus are a necessity but can impact your computers efficiency since they do eat a fair amount of resource.
sacredrays
you put everything high? i'm using 750ti too and the 10v10 will make my fps drop when everyone use their big graphic spells.. :s13::s13:
OrdinaryMoon
Hi sir,thanks for the advice. But what is PSU and how to know if its sufficient to run your computer?
OrdinaryMoon
Oh so its not only me? i put as default i think. but usally during teamfights and also ember's spirit flame shield makes my fps drop like mad. It shouldnt be the case since everyone tells me my gfx card suffices for dota 2... sigh
sacredrays
don't worry so much.. i just play as per normal... 10v10 is just to have fun.. the normal dota matches still good.
