Original Lightning Cable
DrSheldonCooper
Any places to buy cheaper than apple stores?
Just ruined my cable by dropping one end into a cup of water. A bit sot sot alr.
Original one sure better than the other cheap cables you see on the street right?
GreenHorn
I am using the Griffin one, 10% off $29 at challenger.
If you use iOS 7, only get those cables with "Made for iPod/iPad/iPhone" printed on the box.
kikham
Yes am using the griffin one too,seems more durable than yhe original cable.They have a shorter 60cm cable too at $22 iirc before discount
DrSheldonCooper
Thanks for the recommendation guys. The griffin one really solidly built. Much cheaper than original apple one also.
Tuakong
No point buying cheapo ones....I bought a few and cant charge after using for 1 month.
Buy 1 good one can last.
unknownguy95
Yes, personally am also using the Griffin one and it works better than the original Apple cable. Oops. :/
lostboyz
I bought the 1m griffin cable. $23.20 after member discount. Hope it's better built than apple cable. Plus it's black in color so wun get dirty easily
galliano
I too just bought a 0.6m griffin cable $20 after Challenger member discount.
Works fine so far with my 5S.
Did'nt want a long 1m cable.
benlau1
Bro- so hows your review of this? I was at challenger earlier and was deciding whether to buy this or not.. $20 for a cable which is only a bit cheaper than the apple original cable which is longer... hmmmm
Your review?
galliano
Your review?
Ehh. . Sorry bro. Dunno how to review cables.
Will update when it breaks down. Which I hope you never hear from me. Haha
