[PC Case - endless stackable mATX] Introducing The Thermaltake Core X2 mATX Cube Chassis
MacClipper
Core X Series presented by Thermaltake
Thermaltake - Home
Core X Series Comparison Chart
Stackable for Enthusiasts
"Core X2, the first mATX chassis of Core X Series presented by Thermaltake, is a cube case offering endless stackable capacity and expandability for enthusiasts to create massive liquid cooling systems, utilize as a file server as well as accommodate dual systems..."
To be continued...
MacClipper
Core X2 Features
  • Stackable for Enthusiasts
  • Remarkable Expansion
  • Great Ventilation
  • Chambers Concept
  • Fully Modular Design
  • Interchangeable Window and I/O Panel
MacClipper
Packaging
Nice informative printed brown box which appears kinda oversized for a mATX case so the mATX Asus Gene VII motherboard box has been placed on it for comparison. Yup, this guy is seriously big... well, there is no other way anyone can squeeze in all the above goodies like 2 x 360 rads side by side.
Straightaway, anyone can tell that the Core X2 is not aiming for compactness even when using a mATX foundation but has instead reached for the bells and whistles in a no holds barred decked out monsta mATX rig.
MacClipper
Heheh, the aim for this TT case as stated in post #1 is actual functionality rather than looks or size.
MacClipper
Unboxing
The 2 protective Styrofoam moulds appear to have done a great job in securing the test unit cos it arrived in pristine condition.
allhomme
wow finally some case manufacturer decided to look at caselabs' Mercury series and do something about it. I would say that the Core X2 is heavily influenced by the Mercury Series and if Thermaltake would make one for full ATX I would be very happy.
MacClipper
The meshed metal top is easily removed by undoing 2 captive thumbscrews (nice!), exposing the 2 sturdy horizontal rigidity bars (even nicer!).
MacClipper
Side Panels
One windowed and one meshed and they are inter-changeable depending on your needs, flexible!
The user panel of buttons/LEDs, USB3 ports and audio jacks are seen in their default position and this can be switched to the other side too, great design indeed.
MacClipper
Yes that's right, actually detailed way back in post #1 if anyone had clicked on the link.
So here it is again, comparing the full Core X series
HTH
MacClipper
Back
Note the bundled 0.30A exhaust 120mm fan, rubber grommet and the fenestrated I/O plates
