pc/gpu will not start up.
1315WEN
Hi guys my graphics card is sort of dead to me. Everytime i turn on my pc o have to switch the bios switch on the gpu back and forth to get it working. If not there will be no display. Any bros out there that can help me solve this problem? I can't even game properly.
My specs:
INTEL I5-3470
ASUS P8Z77-V LK
KINGSTON ram DDR3 PC12800/1600MHZ 4GB
TOSHIBA 1TB 3.5 SATA 3 HDD
MSI 3GB R7950 TWINFROZR III DDR5
WINDOWS 7 ULTIAMATE 64 BIT.
The gpu fan is still running when turn the pc on
Edit: Things that i've done.
Change wire
Switch to onboard graphics
take out and insert the gpu in again.
put the gpu into another pcie
Edit:
Now there's absolutely no display at all now.
tuckloong
My specs:
INTEL I5-3470
ASUS P8Z77-V LK
Change wire
Edit:
Try remove all rams....clear cmost and then boot with 1 stick of ram..insert the GPU and try booting
jtjt00
When testing with GPU, you plug in the PCI-E cable?
sanfong
Have you tried the boot up with one ram at the time as mentioned earlier?
1315WEN
Yeah I plugged in the PCi-e cable to the GPU. GPU fans are running, but no display. Tried to boot with one ram. Still can't get display. It boots up when I'm using integrated gpu
tuckloong
Hmmm time to send the card in for checks le? Do u have another spare graphic card to test?
suavegamer30
Sounds like graphic card is spoilt...but u have to test it out if u have spare ones.
