no need k if you don't intend to oc and if you are oc-ing then better not use itx cases with low profile cooler.
edit: perhaps an AIO is better?
Cryorig C7? It's 47mm tall.so if i get 8700, low profile air cooler ok?
Sent from HUAWEI Mate 20 using GAGT
This one too high liaoCryorig looks the best, Noctua variants seems to have slightly better temps
https://www.techpowerup.com/reviews/Noctua/NH-C14S/9.html
this looks cool if you are able to mount it this way
Yeah lor, There r mixed reviews on low profile coolers on 8700 non-k. That's why I m confused.
I try not to use 240mm aio. Cos I considering the Ghost S1 case. Using aio, meanings I have to add a tophat thus increasing the overall height of the case.
So seeking the advice here.
CoolerMaster Hyper 212 Evo![]()
I don't think the Cryorig C7 is meant for CPUs like the i7-8700. You will need something beefier, either the Cryorig C1 or Cryorig C7 Cu. The latter seems to be rather hard to find though.
i need a low profile, max height 66mm leh![]()
if not, i get noctua L12 & replace my rams to low profile rams OR get a 240 AIO liaoi don't think you have much choice le
itz your money your call, just that going small has lots of headaches.
btw L12 with fan is 93mm
https://noctua.at/en/nh-l12/specification
