SkyShroud
- Oct 28, 2005
Hi all,
1st problem
I notice I am unable to visit some site, so I used the /flushdns command. At first, after using it, I am able to enter the problematic sites. However, an hour later, I no longer able to browse those sites, I have to use the /flushdns command again. Is there any way to fix this? Only this pc is having this issue and my other pc is fine.
2nd problem
When I tried to logon some site, it doesn't logon right away, I have to login a few times before it work. This problem only occur on this pc, might be related to the first problem.
Any idea?
1st problem
2nd problem
Any idea?
