PSU for Lian Li 207?
Phen8210
Current specs:
  • Ryzen 7 7700X (OC/PBO enabled)
  • Zotac RTX 5070 Ti
  • Lian Li Lancool 207 (planned)
  • 2 x1 16GB DDR5 RAM Kingbank Dark Heatsink
  • B650M Plus WiFi
I'm planning to change my case to the Lian Li Lancool 207.
Since the case has a relatively short PSU length limit and its a front-mounted PSU design, PSU cables provided need to be able to reach the MB connectors etc. I'm looking for recommendations on a suitable PSU, 850W and above.
KleoZy
Your best bet is to find PSU that is not having depth more than 150mm ... below are what I've tested, most PSU are with flat cables except for Lian Li, as flat cables are extremely easy to cable manage in Lian Li 207. Though Lian Li are sleeve cables but it's still easy due to the small footprint. You might want to wait for other bros here to list some others.
Note : Use original modular cables and not extension cables.
1) Lian Li SX850P [140 (D) x 150 (W) x 86mm (H)]
2) Montech Century II 850W [140 (D) x 150 (W) x 86mm (H)]
3) Asus TUF Gaming 850W Gold ([150 (D) x 150 (W) x 86 mm (H)]
4) Adata XPG Core Reactor II VE 850W [140 (D) × 150 (W) × 86 mm (H)]
5) FSP VITA GM 850W [140 (D) × 150 (W) × 86 mm (H)]
6) Asus Prime 850W AP850-G [150 (D) x 150 (W) x 86 mm (H)]
Power Supply UnitDepthEfficiency TierATX SpecKey Advantage
Lian Li SX850P140 mmCybenetics PlatinumATX 3.1Genuine Platinum efficiency, individually braided premium cables, manual Eco switch.
Montech Century II 850W140 mmCybenetics PlatinumATX 3.1Best value, excellent internal platform, quiet grille mesh design, manual Eco switch.
FSP VITA GM 850W140 mmCybenetics Platinum / 80+ GoldATX 3.1Built by a tier-1 component OEM. Elite ripple suppression, but fan runs continuously.
Adata XPG Core Reactor II VE 850W140 mmCybenetics Gold / 80+ GoldATX 3.1Fully modular, highly affordable, but fan gets quite loud under continuous heavy load.
Asus TUF Gaming 850W Gold150 mmCybenetics Gold / 80+ GoldATX 3.0 / 3.1Highly rugged build, massive 10-year warranty, but lacks an Eco switch and runs a bit warm.
Asus Prime 850W AP850-G150 mm80+ GoldATX 3.0Great aesthetics (reversible black/white side accents), but older ATX standard and no zero-RPM fan mode.
Phen8210
frm cybernetics ytd i did rough check there was superflower model for 1000 rank 4 overall but it was using 9 pin on psu side and also the cables r not flexible, quality psu for sure but these 2 caveats make me wanna reconsider, have to say that my budget below 250 for 850/1000 w models
Jurchen King
No need to think already. Seasonic Vertex 850W Gold ATX 3.0 = $239. If want to save more, Seasonic Focus 850W Gold ATX 3.1 = $210. Both 10 years warranty.
Can get from either Dynacore or next door VII Computers.
NightRaven49
personally wouldnt even consider these as they do not perform as well as the others, especially for the budget ts has in mind where genuinely good options can be had. the lian li sx0850p would be my pick as it is among the best performing locally available units around $200, and at 140mm long should fit comfortably in the lancool 207's limit of 160mm.
curious to know why this would be a downside.
its 160mm long, right at the limit of the lancool 207, may be harder to manage the cables.
Phen8210
i mean if I'm ok with 160mm i would have went for CORSAIR RM850x Shift :D, 225 on amazon only
my current psu is a leadex II 750W, def great during its time, i wished i could continue using it, but its 165mm that's why ill need a new psu
Phen8210
i wonder if the model is called sx0850 or sx850
when i search 0850 i cannot find, funny ah lian li
kimsix
Leadex 8 pro platinum 1200w only $230++ after shopee vip, is small size and use standard 12v hwpr 3.1 connectors
1000w can get now $210++ if scared oos
Phen8210
ya, i saw ytd
just dono if i wanna live with the stiff cables :D
kimsix
ya, i saw ytd
yes you will want it. This 8 gen fixes 7 gen problems by using standard 12v hpwr holes, you can use any replacement like rog equaliser :o
their 7 gen used their proprietary 9 pin and users noted it causes current imbalance at gpu side
The newer fish scale sleeves is softer a bit than their 7 gen cable too. The extra cuttings make it easier to bend
It is not corsair braided soft but you will want it!
Phen8210
after thinking for awhile. i decided to go with this, since superflower def way more experience with building PSUs..
dono where the shopee vouchers recently though, all gone liao
MangoCAT
should be 6.6 or 6.18 or june payday? - > not sure since is up to shopee to disburse their own vouchers
kimsix
can always go simlim got open today buy
✅ Price - ⭐ SUPERFLOWER LEADEX VIII Platinum PRO ⭐
🔹 LEADEX VIII PLATINUM PRO 1000W - $207
🔹 LEADEX VIII PLATINUM PRO 1200W - $243
✅ Self Collect - . Mon to Sat 11am to 6pm . Sundays & PH Closed ✅ Shop - Sim Lim Square #06-41 Singapore 188504 ✅ FB - @PCKAKI ✅ IG - @pckaki.sg
yukita
do we really need such a high power PSU?
TS spec looks okay to use 750W.
A good 850W has alot of buffer already.
kimsix
Yes! needed!
the more power we buyed the more we saved, because of AI nonsense buying up everything
yukita
yes, price looks good for 1200W psu. cheaper than my corsair sfx.
KleoZy
You hit the right spot (y)(y)(y) that's why I place them below from the my chart. If I have the budget at $200+, I will go for the Lian Li SX1000P. Ive tested these units while benchmarking processors with mobos and GPU.. the SX1000P and SX1200P againts Seasonic Vertex PX1000 and PX1200. These Lian Li PSU are rock solid performer. Not only that, while maintaining PCs for friends or colleague's who took up the recommendation, the voltages stay strong. Hardly any significant vdrop.
On top of which.. cables are long, cable management is super duper easy due to the PSU Depth at 140mm.
thanks for your insight too :)
