PSU with monitor outlet
u0206397
Why modern PSU has no outlet for monitor power? Most PSU are 500W and above. and some light PC are using less than 200W or even 100W?
u0206397
CPU 10 or 20 years ago were less efficient.
CRT monitor years ago used more energy.
Thus, together they place a heavy stress on the PSU, which was why they decided to split the monitor power to a separate cable and power plug.
However, both are no longer true today, and PSU are mostly underused, except for those gaming PCs with powerful GPU that taxes the PSU.
cscs3
Cost saving. Also partially due to atx2.0 and up design. Today, almost all pc trigger power on by using 5v standby power. This power also use to hold data in ram in case you put p. To sleep and not power off.
In summary, unlike old power supply. ATX power supply always has 5v running. To have another 230v output to monitor, this means more circuit is needed within the power supply vs in old day, using on off switch to power on off.
blackestvoid
a stupid feature
if the psu chibaboom it fries both the cpu and monitor
i also rather use power plug cables rather then extension cables
wwenze
I guess none has actually opened up to see how it looks like inside
wwenze
The output socket is simply wired to the input socket
Alphas
a stupid feature
Nope, it is a parallel connection, so it does not affect the monitor.
cscs3
It depend. In old day. Cheap one wire directly. Better design is thru the switch. So monitor get turn on when PC turn on.
cscs3
a stupid feature
Not stupid but very useful feature if you have limited wall plug.
What make you think monitor is taking regulated power from psu? Is no different like you are using a extended power point.
wwenze
In old day, PSU couldn't shutdown on its own. Power was directly controlled by cutting connection to AC via the switch.
The rest is the same - monitor outlet still gets connected parallel to the PSU. Except both are behind the switch.
wwenze
The below shows why switching capability was easily implemented in AT but naturally went away in ATX.
There are also oddballs that did the below:
But a switch capable of switching 230V 13A is expensive.
cscs3
there was a time when PSUs could shut down on their own and still have a monitor outlet.
The last I have seen of any switched PSUs was my 1993 Packard Bell...
Thats correct. I habe one of these. But tge output is wired directly to input so you have to manually power off the monitor is connected there.
