recommendation for mITX casing smaller than NODE 202
rvyne7
Hi,
I just want to check if anyone can recommend a mITX casing that are smaller than NODE 202?
Given away my previous rig with NODE 202...still trying to determine which route best to go after.
My option is limited eGPU, extra gaming laptop dedicated for gaming (with at elast GTX1060) or rig smaller than NODE 202 (I still find it big in my room).
The case still require to fit a GPU, atleast 2x 2.5 SSD/HD and PSU
Shahmatt
Logic Supply MC600?
You need to go with a Pico style PSU and external adapter.
