Recommendation for spring coil USB A to C cable for car use
galapogos
Moderator
Moderator
Hi,
I'm looking for a spring coil USB A to C cable for use on my car. I have been using Baseus which I thought was a decent brand, but the connection becomes very bad after a few months, maybe due to the heat. Are there any better cables out there that last?
jtjt00
Go to Sim Lim Square Worldwide Computer at 6th floor facing lifts. Can't expect to last long if car is parked under hot sun.
yusoffb01
get usb c to usb c instead. better built to charge 100w. should last longer.
Hi,
not much options for such.
galapogos
Moderator
Moderator
My car USB in is Type A, so no point getting C-C. Also, I noticed that the Type C end is the finicky end (shake liao will disconnect). The Type A end seems to be fine (shake liao still connected).
Phen8210
What is spring coil?
galapogos
Moderator
Moderator
So is what?
Charging cable but in coil version?
Why would ppl use this type coil lol
To minimise cable clutter in the car.
No such.
But maybe you can try braided right angle cables.
Haha, I actually have this exact cable, but using it for my laptop instead. What do people use in the car then? Seems like regular cables don't stand up to high heat
gamma15
If you are using CarPlay or Android Auto, i would suggest instead of coiled, why not a short cable,
i'm using a Baseus USB A to C... so far so good
ZhuTou!
Hmm why need to minimise?
My whole car can only see 1 cable lying around and that is the phone charging cable
Camera cable is hidden all the way
So what other cables u have lol
U buy those sleeved type of cable, can use very long
Mine is like few yrs alr still working fine
