[Recommendation] SFF / Mini ATX Cases
kenneth534
Size matters a lot to me, so I've been thinking of building a small form factor rig (oops i meant mini ITX yes) with mid-range specs.
Roughly something like this:
AMD Ryzen 3600
Stock or AIO cooler?
Nvidia GTX 1660 Super
16 GB Memory Dual Channel
512 GB NVMe SSD
500W SFX PSU
Anything overkill? Would like to know if there's any good mini ATX cases out there.
gonnie
Mayb can consider 3400g? No need 1660super haha
Sent from HUAWEI VOG-L29 using GAGT
wwenze
I honestly don't get NR200 design choice when it could have fitted mATX mobo easily if they gave it just one more slot worth of height
I mean just look at this
xtwis7
Got pretty much the same specs for my friend’s ITX build. Can’t go wrong with the Cooler Master NR200P.
TanKianW
Mini-ATX?
You meant Mini-ITX I guess.
I will take a look at InWin, Louqe, Silverstone, iGeeek, Jonsbro, Chenbro, MIC no brand cases.
After 2017, all my new pc builds are mITX.
mITX pc build cases:
NightRaven49
2 matx cases that has similar layout to nr200 i found on taobao are the sktc hx100 and the airola (艾罗拉) m40 plus. there are also variants of these cases that support smaller 245mmx215mm mobos and/or full sized atx psus, but these in particular are very similar to the nr200 in terms of compatibility, while being smaller too (~15l).
sktc hx100:
airola m40 plus:
zleipnir
I'm using a Phanteks ShiftX
The popular ones are
1. NZXT h1
2. CM NR200P
3. NCASE M1
SSpider87
Aigo Yogo S1 on taobao if you like vertical cases but don't want to deal with PCIe 3.0 extension cable.
katata
I’m using an ncase m1. Wanted to go for Dan a4 cuz smaller. Good thing I didn’t, first time build ITX didn’t expect so much difficulty with the cables and stuff
kicknikuku
I'm using silverstone sg13 and I like the form factor of it. I'm using an atx psu with it so it was quite difficult to build with. It does not come with the sff bracket that should make it easier to install (not sure if local distro can bring in).
