Red LED 140mm fans
Sensational
Hi guys, I am looking to replace the rear fan of my corsair 760t case for a red LED 140mm fan. Any recommendations for a fan like this? All inputs will be appreciated! :)
mangopudding
i using corsair 140 quiet edition led ones. but they are my front intakes thou.
i think with all led fans, if the fan speed is decreased, the led also will be dimmer.
Sensational
yea i was looking at that as well since it is from the same brand.
definitely man. the 760t the front 2 fans when u lower the speed the led will also dim abit. haha.
But how is the fan like? noisy or anything?
mangopudding
i using quiet edition ones, and normally run lowest when idle, not much sound.
i think there are better fans out there, but maybe the color scheme will off a bit.
freakerknoid
I replace mine with the quiet edition (blue). They do run a bit quieter than the stock, but i don't think there's a large different. For me it about the bling..:s13:
Sensational
haha yea but I read about things like static pressure and airflow man. i guess that would matter also in the case of a fan right? that is why I wanna see if there are other fans that have the red LED and provide good cooling. LOL!
mangopudding
Sp fans are more for radiators. Or if your fans are infront or behind something blocking wind flow.
Do take note of pwm fans too. And if your mobo supports true pwm.
Sensational
okay so i guess if it is for the rear fan then the af140 would be fine? haha
