Removing Battery
murphyp
Hi to all old birds
is it advice to remove Alienware AW17 internal battery and just use power supply? not taking out to use at all.........only at home.
thanks
Cryogenist
Hi to all old birds
thanks
Hmm.. Why not...
But before you take out the battery, drain the battery to around 40-50% charge.
This will lengthen the shelf life of the battery while you kept it for long-term storage.
lemonn
Please post in the correct sub forum next time, thank you.
