MBBSclinic
- Dec 18, 2013
20% power return back
Don’t really get what you mean by resit.
Do you mean taking it out and plucking it back in?![]()
Hmm try running an app, it will probably drop real quick!
i am asking how did resit battery can return 20% power?
why u tell me to run app to make it drop again?
If you have used that phone for quite some time (e.g 2 years ), it's normal for the battery reading to be off. This is because battery capacity drops over time.
For example, sometimes my phone stops charging at 70%, but after resitting, it increases back to 90%. My battery is probably 70% of what it used to be
Can't be helped. Old battery can't hold charge well.
Sent from LENOVO using GAGT
time to change new battery?
