focus1974
- May 12, 2007
What is the effect of the ride ? if you put on Rims specs different from OEM?
I found my Merc w212 uses 17inch rim spec with 8jx 17 , offset ET48, and pcd 5x112.
But I went and itchy backside changed at a tyre shop ... to the newer rims form a C class.. which is lgihter and smaller car
So the Rims spec is 17inch spec with 7x17 , offset ET48 and pcd5x112.
SO will the rim width off by 1inch ... affect the quality of the ride?
and worse ... i just found out
a 7x17 .. should not be using 245/45 17inch tyre... max supposed to be only 225/45.
https://www.tyresizecalculator.com/charts/tire-width-for-a-wheel-rim-size-chart
so.. any suggestion how to improve the ride?
Should I change the Rims ...or will changing the tyre to the correct width be good enough?
