lifeisshort
- Apr 9, 2019
Hi, need some help on the following.
Using Singtel Fiber Optic network now. I have 1 gang of 5 data point in the distribution box (DB) to various areas in the house.
My modem and the DB are inside the cabinet.
1. Previous Setup
a. Modem to one of the data point (1) in the DB.
b. data point (1) outlet is at the living room where my TV box and wireless router are.
c. connect data point 1 to wireless router and 1 cable point from the wireless router will be going to the TV box.
d. wireless router will supply network to the rest of the house.
Singtel replaces the modem and router for me due to very slow connection. They provided me with the wifi mesh with only 1 inlet for the Ethernet cable and no outlet for the cable.
2. Present Setup
a. Modem to Wifi mesh directly.
b. Modem to Data point 1 for the TV box in the living room.
c. as the Wifi Mesh does not have the outlet for the Ethernet, i have to keep the Wifi Mesh in the cabinet, near to the modem. I cannot do the same as 1c as per my previous setup. Due to the reason, i do not have any network in the rooms. Only Living room has it.
What can i do to enhance the network to all the rooms?
Can i use Switch? Should i buy another Mesh extender? or others?
Please kindly advise me.
Thank you.
1. Previous Setup
2. Present Setup
Thank you.
