Solar power phone kym¿
Honeydewz
At MWC 2025, Infinix's Solar-Powered Phone Can Recharge With Ambient Light​
New tech at Mobile World Congress could let you charge your phone when it's out in the sun or even under room lights.
Headshot of David Lumb
David Lumb
March 5, 2025 4:12 p.m. PT
2 min read
A hand holding a phone with a shiny gray-and-patterned back cover.
Infinix's solar power technology is inlaid into the back of this prototype version of the company's Note 40 phone. Note the vertical white oval light in the top-center of the phone, which indicates the solar charging is working.
Tara Brown/CNET
Mobile World Congress is the biggest show of the year for phones, and at MWC 2025, companies have shown off some very intriguing concept devices with cool tech for gaming and folding displays. But Infinix is pitching something else: solar power in the phone itself to charge its battery when users are out in the sun.
At the show, Infinix demonstrated its SolarEnergy-Reserving technology, as it's called, on a prototype of the company's Infinix Note 40 phone and a version of its upcoming Infinix Note 50 phone wrapped in a proprietary solar charging case. In both solutions, small circular lights on the back of the phone near the rear cameras winked on when solar recharging was active. The phones also had pop-ups on the front display acknowledging charging.
A close-up of a phone held in hand in front of a city sidewalk.
Here is a closer look at the prototype Infinix Note 40 phone with the company's solar charging technology. The vertical white circular light next to the cameras indicates the solar charging is working.
Tara Brown/CNET
The technology is still in testing, and the implementation on the prototype devices isn't final, so a lot could change before it makes its way to market-ready devices. For instance, the case solution connects to the phone via a set of pins on the side that match up to conductive connectors on the handset. But at MWC, Infinix told CNET's Tara Brown that the tech can charge up to 2 watts, recharging around 10% battery life in an hour.
That's slower than conventional wireless charging (which can get up to 25 watts in the newest phones) and far slower than wired solutions that can go from 45 to 200 watts or more in some handsets. But the virtue of passive charging wherever your phone is, so long as it's facing a light source, would be very convenient -- especially for folks eking out more battery life in emergencies.
While Infinix's solar tech was implanted in the back cover of the prototype phone or the case on the other device, meaning the backside of the phone would have to face a light source, it runs on all ambient light -- not just sunlight -- which would include indoor lighting, too. Infinix's AI-driven "Sunflower" wireless charging tech, as it's called, adjusts the energy transmission path depending on external lighting conditions and how the device is positioned.
Read more: MWC 2025: The Weirdest Phones We've Seen
Infinix is looking for applications for its solar tech beyond smartphones, like wearables and other digital devices. Other companies at MWC 2025 also had solar power concepts, like the Anker Solix Cloak, which recharges devices when worn.
Infinix also introduced a different concept technology at MWC 2025: E-Color Shift 2.0, an evolution of its previous tech that uses AI-controlled modules on the back of a phone to shift colors and patterns depending on factors like weather, wallpapers and surroundings.
Hello_Kitty
if everyone charging using the Sun, then will eat into electricity companies' profit???
Apparatus
Cheah my SAMSUNG TV remote also can do ah. Face the room light means can charge liao
What's the high tech here?
deathan9el
Honorary Mentor
for construction workers use?
who else would be working outdoors or even stand under a scorching weather just to charge the batt?
luei74
Think hybrid more practical bah...boh sun use electricity to charge
Hypernova
i got a bright(pun intended) idea.
get two infinix phones turn on the torch light mode and shine at each other. Tadah! unlimited power!
