Hi,
I recently bought an Asus RT-AX58U V2 (AX3000) with the latest firmware 3.0.0.4.388_22525 and I am having issue with loading up the Singtel TV. My internet and wifi are working. My subscription plan is the fiber 1GB plan and it is using ONT. I have configure the Asus router to "Singtel others" and plugged to LAN 4 for the singtel tv.
I have tried changing the isp profile to "Singtel mio" and "Singtel multi STB". Tried manual as well with:
Internet VID 10 PRIO 0
LAN PORT 4 VID 20 PRIO 4
I have also tried LAN port 3 with VID 20 PRIO 4 set as well and connect the Singtel TV to LAN 3. Reboot the ONT, Asus router and Singtel TV and on them in sequence (ONT --> Asus router --> Singtel TV) after every setting change.
Have connected Asus and they check though all the setting as mentioned above. They suggested me to call Singtel and comeback to them if the solution is not resolve.
So I contacted Singtel and they did a backend diagnosis check, suggested the above mentioned setting, reload the system at their end and even sure the green light (LINK) is on at the Singtel TV box. Their solution is to change the ONT to ONR so that the Singtel TV can directly connect to ONR instead of the Asus router. They also agree that there will be drawback in performance if change to ONR. So I think I will keep it as the last resort if there are no solution.
Contacted Asus back and their solution is to bring the router to their service center to get the LAN ports check.
I have tried test all 4 LAN ports to see if there are any internet connect with the ISP profile set to manual:
LAN PORT 4 and LAN PORT 3 leaving them blank. All 4 LAN ports have connection to the internet.
The Singtel tv mode that I am using is Tatung STB-3002 (the model that allow tv recording in HD).
Before I bring the Asus router to the service center, has anyone came across this issue (Singtel TV not load up only) and manage to solve it? Any help will be appreciated.
Thank you in advance.
