my creative t12 speakers suddenly no power / dead. power display no light. computer detects the speakers though. maybe the power cable is faulty. can I buy an equivalent cable from sim lim tower ? how much is it ? if it is cheap, maybe buy it and try.
Most likely the fuse inside the speaker has blown. You will need to open up to replace it and see.
If the set is still under warranty, i would highly recommend you to bring the invoice and the product down to Creative @ International Business Park for check.
Computer still can detect meaning via Bluetooth or via Realtek jack detection? The jack detection just tell you physical connection is there but don't care whether the speaker works.
Mainly I would suspect the power adapter. If adapter got led light, see whether got light or not. Can also check with multimeter.
12V 1.5A shouldn't be hard to find nor expensive, but you should find one to try first. Any old cable modem or external 3.5 inch HDD? Lots of things run on 12V.
