TENDA NOVA MESH setup issue
athletic91
bought a set of mw5s during 1111 sale.
connecting the main node to the modem could not get a internet connection despite many tries and reset.
tried my luck to reinstall my old asus router, then connect the nova main node to the asus router using lan cable and now the nova mesh system works.
i removed my asus router and connect the nova node directly back to my modem and can't get the connection again.
any idea what when wrong?
Using SingTel ONT? Then you need one router with Vlan support.
kashix
Ur network is vlan tagged, you have to use your Asus then passthrough to your tenda unfortunately.
