Ubiquiti U7 Pro
ddgp1105
Unbox 😍😍😍
Made in Vietnam, first time saw Ubiquiti product made in Vietnam, next generation made in India?? πŸ₯Ά
Test Date Jan 2023 ? one year ago already done and test ??o_O
Unifi AP Pro --> AC Pro-->U7 Pro ( where is U6 Pro ??? i don't have πŸ˜†)
As the three generation "PRO" version loyal user, this time U7 Pro packing and product quality, a bit disappointed.
feel like basic product πŸ€ͺ previous Made in China feel much solid and exquisite.
U7 Pro online
Overview
Settings, 6 Ghz Radio πŸ˜‚ πŸ˜‚
Insights
to be continued.............
ddgp1105
yes, as other brand router change to US the 6ghz enable, but i will setting to Singapore as ubiquiti already remind me leh πŸ˜‚
htancl
u7-PRO US version can be used in Singapore? Any restriction in any of the feature?
I ordered from US Store but decided to cancel as worry about the compatibility to use in SG.
ddgp1105
U7 Pro - 5 Meters PC1 (wifi6)
U7 Pro- 15Meters -2 wall- PC2 (wifi6)-openspeedtest
U7 Pro- 15Meters -2 wall- PC2 (wifi6) -speedtest
few day use , coverage and stable is satisfied as expected. πŸ‘
ddgp1105
the restriction is by Country/Region you setting. 🌍
if you are asking the 6 GHZ
UniFi Network - Regions Supporting 6 GHz
**Additional countries and their minimum versioning information will be added as they become eligible.
i don't know what will the different for "SG version" , maybe made in India ? πŸ˜‚
MasK
Could the test date be actually 1st Dec instead of 12th Jan? :unsure:
BradenHeat
Unbox 😍😍😍
U7 Pro online
Overview
Insights
Color me surprised,
MiV ? not bad
but early adopters' tax sure is gonna be hefty
but yea, our local tech govt , under a certain useless bunch, will be slower than other countries
6Ghz will be interesting,
however, hopefully there will be support for MLO, officially without the need for hardware spec changes
e.g if its parallel, then it will be doable when moving room to room, or room to toliet
MasK
Could be MM/DD/YYYY. :unsure:
Yup, confirmed it's MM/DD/YY.
Just got the U6pro and I was told the cheap packaging is the newer batch of devices which environmentally friendly.
Test date of mine: 11/16/23. Made in Vietnam.
Older packaging was tested on 2022! o_O
mrkiasu
My little contribution:
ddgp1105
thanks for sharing ,U6 Pro look like same size with AC Pro , U7 Pro big & more heavy ...
so far ,U7 Pro serve me well. for home use , ,my 16 total connections full coverage no issue.
be honest ,a lot stuffs still connect with WiFi 4 πŸ€ͺ
ddgp1105
Finally, I got a 6GHz-Wifi 7 client (mobile phone) for my U7 Pro 😍
The speed test is lower than expected, but at least it's over 1 Gbps πŸ˜‚
BradenHeat
Hijack :
anyone gotten the u7 pro MAX ?
really keen to see if the real time spectrum analysis is worth the additional cost
I6 Pro Max
Speed is normal.
It seems to be confirmed that iPhone 16 generation, including iPhone 16 Pro and Pro Max do not support 320MHz channel bandwidth on the 6GHz band, and only 160MHz channel bandwidth. Flagship Android phones support 320MHz channel bandwidth on the 6GHz band and can hit above 3Gbps wireless speed.
Even with the same 160MHz channel bandwidth, it is a bit slower than flagship Android phones which can hit a bit higher at 1.8Gbps or even 2Gbps. iPhone 16 Pro and Pro Max seems to be at about 1.6Gbps at the best.
Reference:
https://wccftech.com/iphone-16-wifi-7-performance-is-slow/
