shichuanhua
- Mar 2, 2012
Hi guys , I'm considering upgrading RAM for gaming purpose
I'm using Dell Inspiron 7447
some details of my laptop as follows
I'm thinking about getting 16GB ram via amazon ,but not sure if local gt any better deals
Code:
Processors
Number of processors 1
Number of threads 8
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 4)
Number of threads 8 (max 8)
Name Intel Core i7 4710HQ
Codename Haswell
Specification Intel(R) Core(TM) i7-4710HQ CPU @ 2.50GHz
Package (platform ID) Socket 1364 BGA (0x5)
CPUID 6.C.3
Extended CPUID 6.3C
Core Stepping C0
Technology 22 nm
TDP Limit 47.0 Watts
Tjmax 100.0 癈
Core Speed 3292.1 MHz
Multiplier x Bus Speed 33.0 x 99.8 MHz
Stock frequency 2500 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 6 MBytes, 12-way set associative, 64-byte line size
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 25x
Max turbo ratio 35x
Max efficiency ratio 8x
O/C bins +2
Ratio 1 core 35x
Ratio 2 cores 34x
Ratio 3 cores 33x
Ratio 4 cores 33x
TSC 2494.6 MHz
APERF 3292.9 MHz
MPERF 2494.7 MHz
IA Voltage Mode PCU adaptive
IA Voltage Offset 0 mV
GT Voltage Mode PCU adaptive
GT Voltage Offset 0 mV
LLC/Ring Voltage Mode PCU adaptive
LLC/Ring Voltage Offset 0 mV
Agent Voltage Mode PCU adaptive
Agent Voltage Offset 0 mV
Temperature 0 58 degC (136 degF) (Core #0)
Temperature 1 58 degC (136 degF) (Core #1)
Temperature 2 59 degC (138 degF) (Core #2)
Temperature 3 56 degC (132 degF) (Core #3)
Temperature 4 58 degC (136 degF) (Package)
Voltage 0 1.09 Volts (VID)
Voltage 1 +0.00 Volts (IA Offset)
Voltage 2 +0.00 Volts (GT Offset)
Voltage 3 +0.00 Volts (LLC/Ring Offset)
Voltage 4 +0.00 Volts (System Agent Offset)
Power 0 38.16 W (Package)
Power 1 23.91 W (IA Cores)
Power 2 4.51 W (GT)
Power 3 9.74 W (Uncore)
Power 4 2.72 W (DRAM)
Clock Speed 0 3292.14 MHz (Core #0)
Clock Speed 1 3292.14 MHz (Core #1)
Clock Speed 2 3292.14 MHz (Core #2)
Clock Speed 3 3292.14 MHz (Core #3)
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format SO-DIMM
Manufacturer (ID) Micron Technology (2C000000000000000000)
Size 4096 MBytes
Max bandwidth PC3-12800 (800 MHz)
Part number 8KTF51264HZ-1G6E1
Serial number 0CE37592
Manufacturing date Week 32/Year 14
Number of banks 8
Nominal Voltage 1.35 Volts
EPP no
XMP no
AMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 5.0-5-5-14-19 @ 380 MHz
JEDEC #2 6.0-6-6-16-22 @ 457 MHz
JEDEC #3 7.0-7-7-19-26 @ 533 MHz
JEDEC #4 8.0-8-8-22-30 @ 609 MHz
JEDEC #5 9.0-9-9-24-33 @ 685 MHz
JEDEC #6 10.0-10-10-27-37 @ 761 MHz
JEDEC #7 11.0-11-11-28-39 @ 800 MHz
DIMM # 2
SMBus address 0x52
Memory type DDR3
Size 4096 MBytes
Serial number 0CE37536
Number of banks 8
EPP no
XMP no
AMP no
DIMM # 1
SPD registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 92 11 0B 03 04 21 02 01 03 11 01 08 0A 00 FE 00
10 69 78 69 30 69 11 18 81 20 08 3C 3C 00 F0 83 05
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 41 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 80 2C 0F 14 32 0C E3 75 92 81 0D
80 38 4B 54 46 35 31 32 36 34 48 5A 2D 31 47 36 45
90 31 20 45 31 80 2C 44 50 41 45 41 42 34 30 31 36
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
DIMM # 2
SPD registers
70 00 00 00 00 00 80 2C 0F 14 32 0C E3 75 36 81 0D
Monitoring
Mainboard Model 0AM750 (0x0000015A - 0x004FA000)
LPCIO
Storage
Drive 0
Device Path \\?\scsi#disk&ven_hgst&prod_touro_mobile#000000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Fixed
Name HGST TOURO Mobile
Capacity 931.5 GB
SMART Support Yes
Volume e:\, 931.5 GBytes (95.7 percent available)
Drive 1
Device Path \\?\scsi#disk&ven_samsun_&prod_ssd_840_evo_250g#4&21007c43&0&040000#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}
Type Fixed
Name Samsung SSD 840 EVO 250GB
Capacity 232.9 GB
SMART Support Yes
Volume c:\, 207.8 GBytes (27.4 percent available)
Generic USB Hub, class=0x09, subclass=0x00, vendor=0x8087, product=0x8000
Graphics
Number of adapters 2
Graphic APIs
API NVIDIA I/O
API NVIDIA NVAPI
API Intel I/O
Display Adapters
Display adapter 0
Display name \\.\DISPLAY1
Name Intel(R) HD Graphics 4600
Board Manufacturer 0x1028 (0x0680)
Memory size 1024 MB
PCI device bus 0 (0x0), device 2 (0x2), function 0 (0x0)
Vendor ID 0x8086 (0x1028)
Model ID 0x0416 (0x0680)
Performance Level 0
Display adapter 1
Name NVIDIA GeForce GTX 850M
Revision A2
Codename GM107
Technology 28 nm
Memory size 4 GB
Memory type DDR3
PCI device bus 10 (0xA), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1028)
Model ID 0x1391 (0x0680)
Performance Level 0
Core clock 135.0 MHz
Memory clock 405.0 MHz
Win32_VideoController AdapterRAM = 0x40000000 (1073741824)
Win32_VideoController AdapterRAM = 0xFFF00000 (4293918720)
Win32_VideoController DriverVersion = 20.19.15.4360
Win32_VideoController DriverVersion = 10.18.13.6881
Win32_VideoController DriverDate = 12/21/2015
Win32_VideoController DriverDate = 07/10/2016
Monitor 0
Model ()
ID LGD046D
Serial
Manufacturing Date Week 0, Year 2014
Size 13.9 inches
Max Resolution 1920 x 1080 @ 60 Hz
Horizontal Freq. Range 0-0 kHz
Vertical Freq. Range 0-0 Hz
Max Pixel Clock 0 MHz
Gamma Factor 2.2
Software
Windows Version Microsoft Windows 10 (10.0) Professional 64-bit (Build 14393)
DirectX Version 12.0
Register Spaces
Register space PCI
Register space PCI #2
Register space SMBus, base address = 0x0F040
Register space I2C
