USB3.0 problem with touro portable hdd
greykoala
I have problems running hgst 1TB touro portable HDD at USB 3.0 on Windows 7 64 bit ultimate.
When I plug the portable HDD USB 3.0 cable to the USB 3.0 port on the front panel, 2 possible situation happens.
1. "This device can perform faster if connected to a USB 3.0 port" popup appears at system tray, even though it is already plugged in at correct port. File transfer occurs slow especially for large files.
2. The above popup doesn't happen, but halfway through copying the copy process abort and an error message something like "your device cannot be detected" appear. Then the autoplay window appear and the hdd can be detected again. If try copy again same error appears again after a while. This error happens more frequently when transferring large file size.
I tried with the USB 3.0 ports direct from the mobo at the back panel, also same issue.
I tried going to gigabyte website get the latest USB 3.0 drivers and update it. Still same no joy.
Anything I missed?
The hardware I am using you can see on the right.
localITguy
Suspended
Anything I missed?
try USB2 see if got disconnect or not if u copy stuff..
. sounds to me ur hdd is faulty
use a usb3 drvice ( usb stick) plug into mbo see if can detect properly or not
for your case it could be:
  1. USB Cable/HDD Faulty
  2. Mbo Faulty
lobo76
Anything I missed?
Did you set up your comp yourself or the shop? iirc, mobos (some of them) have on the circuit board, usb2 and usb3 ... connectors. If you plug in the wrong one, the labeling on the casing becomes irrelevant.
e.g my casing have usb3-like plug in front, but my mobo only have 1 usb3 out, which is connected to the back.
greykoala
  2. Mbo Faulty
@localITguy
USB2 so far ok, only transfer speed super slow
Tried USB3.0 thumb drive. Seems ok but transfer speed a bit slow.
greykoala
Can try the HDD with another system to rule out issue with the hdd or cable.
@kandinsky
Yes I previously tried with another laptop, no issues or error message popup. Transfer speed also faster and better than what I'm seeing.
greykoala
@lobo76
Shop set up one. I checked the wiring, for sure the front panel cable plug is hooked to the USB3.0 header on the mobo.
greykoala
Try replacing your usb cable.
@Louisloo
The cable came together with the portable HDD. Unless you mean that cable can be bought separately?
Any USB cable will do, no need to be specially for this particular hdd model one?
jtjt00
@Louisloo
USB cable is standard, can cross use with other brands/size.
Louisloo
@Louisloo
Cables can become faulty with the connectors becoming loose through use and giving problems you're facing.
You can buy, borrow from friends to rule out cable fault. Any USB3 cables will do, no need any particular brand.
Providence
I think I better go home and check my Touro 1TB as well. I haven't use it yet though. Now I am scared. :eek:
greykoala
@Louisloo
As my reply to kandinsky earlier, I previously tried with another laptop with no issues. I'm less inclined to think the fault is with the hdd or the cable that came with it.
Looks like I'm gonna beg borrow steal a cable just for testing... >_<
