Recommend a washing machine, please?
zensushi
Moderator
Moderator
Current Samsung washer started to have issues yesterday. Thought of retiring it. Convenient excuse to shop shop a bit. :s34:
This top load WA80F5S7 (8 kg) washing machine has lasted almost exactly 5½ years. :o
Quite keen to try front load washers. Anyone has brand(s) & model(s) to recommend?
Just bought a few packs of washing detergent powder... If I get a front load washer, might have to give the remaining packs to the neighbour. :s22: :s13:
Cut_throat
tbh the best ish Samsung and LG already. :s13::s13: Maybe you can try jump to LG this time. If not stacking then Top load ish still better if not your back jialat.
deathan9el
Honorary Mentor
in before 'front loader saves water more than a top loader' comments :o
zensushi
Moderator
Moderator
We have a separate gas dryer...& the helper does all the laundry. My back is still jialat, regardless. :s34: :s13:
Shall check out the LG washers. :D
VEF888
5.5 years? you have been short changed. Jap brands should last at least 10 years.
Panasonic for top load.
zensushi
Moderator
Moderator
Still working...but since yesterday helper complained that need to power off & restart a few times.
Anyway, for fridges & washers, I'd rather replace them before too long. The thought of using them for decades is...icky. :eek:
