Water dispenser recommendations
bberry
Hi all,
Anyone using bbyeol Altas and Nereos noir snow model water dispenser? Any feedback?
if u use alot of the cold water, then the atlas may not be suitable.
eg, if u top up a 700ml water bottle with cold water, thereafter the water will not be cold, it will take a long while before it gets cold again
Xie_Minghao
U mean once it hit 700ml of cold water dispense, will have to wait for a while for the cold water to be cold again?
Any this issue for nereos water dispenser?
lalalalalala
U can try looking at taobao for reviews. Imo sg most of it are overpriced.
Also imo water filters are pretty much the same technology, the size of the filter is standard
bberry
not exactly 700ml la, thereabout.
so it all depends on yr usage pattern.if u need to like top up cold water in big amount, then Atlas may not be suitable.
i guess neros is from same oem since they look very similar, the tech is the same.
you can always go to their showroom and test out yourself.
if u need higher volume of cold water, consider LG (their tech is different) or tank type.
mrchildren08
Nereos sg has damn poor after service. Sales and marketing has been pushing the products and they get celebrities to endorse it. Once you make full payment. You will probably need to wait 6 months... Or not sure how long to get your purchase. I purchased mine in Feb 2026 and they have rescheduled twice till end of June. How can it be possible for a merchant to not have products for several months but collected full payment from customers? Hmmm.
NintendoSwitch
expensive dispenser got giv wat power to the water?
No idea. My previous one ran out of water after about 2+L. Current one even less. Probably the only reliable ones are the ones at the polyclinics cum hospitals. Those never run out of hot/cold water.
