Where do you keep your dry cabinet?
Apparatus
Just asking. Where you keep?
1) In your rooms?
2) In the hall?
3) In the kitchen?
Keep in room will the room gets warm in the long run?
Thanks
Apparatus
Any comment on the below 90L dry cabinet?
https://drybox.com.sg/collections/consumer/products/90l-dry-box
TK Photo selling a 70L dry cabinet for the same price
keenklee
IMHO.
I keep in the bomb shelter.
A dry cabinet will be as good as it warranty e.g. if need to carry-in, is the service centre accessible or can bring in the faulty part ?
Apparatus
IMHO.
My store room has no place.
IMO keeping the dry cabinet in an enclosed place is not a good idea because the place will get warm without air circulation. Moreover there maybe balanced paints and thinner being kept there too...........so a bit dangerous
RyanJ
If room don't on aircon will it feel warm with the dry cabinet on standby?
Not that I noticed. It is at a corner of the room with no direct light or intentional heating.
Camera and lenses are meant to be for heavy duty use, you already gotten dry cabi to control humidity levels, and at room temps +/- I highly doubt it will shorten component lifespan in a meaningful way.
Apparatus
I'm not talking of component lifespan. I was asking whether the room feels warm as the days go by as the dry cabinet is always constantly on.
If you hand feel the outside of the dry cabinet and it feels warm to touch then heat is a bit high and dissipating to the surrounding
keenklee
IMHO.
Per hour, a person can generate more than 10 times the heat vs the 90L dry cabinet.
If there is some ventilation in the room, should not be an issue.
keenklee
IMHO.
Just to share some information.
I have 3 dry cabinets inside my store. Previous was 2 active, now left 1 active.
There will be at least 1 dry cabinet operating over the last 10 years.
The temperature inside the dry cabinet is about 1-2 degrees higher than the store room temperature.
I set the dry cabinet humidity to above 40.
The humidity inside the storeroom is 50. :ROFLMAO:
alamakazim
If it is working hard... Is pretty warm
Because I didn't close door properly
If it working normally actually is OK la
My sit right under the computer desk
