Why so many ppl buying system 10? How much it cost?
Jiutian7722
Was Queueing at chong pang outlet, overheard one auntie told the cashier she wants 5 system 10 tickets, then another young man also bought 2 system 10 tickets. Then when it's my turn, I told the auntie $1 toto 一张. I felt so embarrassed.
hachi
When all don't tio... You feel smarter? Hahhaha
Retrohelix
Dun BS la. You wouldn't queue up for 30 mins just to buy $1 la.
saltydog
some sole hantu winner will win wib 1 qp ordinary sho dun waste taim :frown:
sg_panda
TOTO Bet Types​
Ordinary Entry​
Select six numbers between 1 and 49.
You win the Group 1 Prize, also known as the Jackpot, if all six chosen numbers match the Winning Numbers.
Bet Type​
Total Numbers Selected​
Number of Ordinary Entries​
Bet Amount​
Ordinary​
6​
1​
$1​
System Entry​
Select up to 12 numbers.
Choosing more numbers gives you more Ordinary Entries in one bet.
Bet Type​
Minimum Bet Amount​
System 7​
7​
7​
$7​
System 8​
8​
28​
$28​
System 9​
9​
84​
$84​
System 10​
10​
210​
$210​
System 11​
11​
462​
$462​
System 12​
12​
924​
$924​
System Roll​
Place a bet on five numbers of your choice and one rolling number.
The rolling number, designated by 'R', represents all remaining 44 numbers.
Bet Type​
Minimum Bet Amount​
System Roll​
5​
44​
$44​
Quick Pick​
If you do not have any numbers in mind, you may consider the Quick Pick option.
The system will generate a random set of numbers for you.
Comparison between TOTO & iTOTO​
  • iTOTO allows you to buy one or more units of a Quick Pick System 12 Entry for the current draw.
  • An iTOTO bet is a Quick Pick System 12 Entry divided into 28 units. Each unit costs $33 (cost of a System 12 Entry of $924 divided by 28).
  • The prize amount for each winning iTOTO unit is the prize amount of the winning Quick Pick System 12 Entry divided by 28.
  • All 28 units of an existing iTOTO bet must be sold before a new iTOTO bet is generated upon demand.
  • By buying more than one unit of iTOTO, you are purchasing multiple units for the same set of numbers.
  • The prize amount will be rounded up to the nearest 10 cents.
https://online.singaporepools.com/en/lottery/toto-bet-types
