Wireless Storage Drive
Hi,
Anyone using wireless drive ? Does this reliable, lost connection via transfer large file?
Which brand is most recommended?
Seagate Wireless Plus
Western Digital My Cloud
wtfh4x
One is portable w/ battery and sets up its own wireless network so you can use it without internet.
The other is not portable and I think you need internet to connect to it, but capacity should be larger.
jtjt00
Forget wireless HDD if your usage is involved transfer large file. It is going to take a long time.
jtjt00
A NAS connected to network can also transfer files wireless. Depending on the wifi standard used, speed varies.
nanoprobe
are u primarily using it at home/office? Uploading 1Gb per file (?) from external is not really fun, can be painstakingly slow if you have like 10 files to upload.
Western Digital My Cloud is a regular NAS on your network with a host of features which allow u to access from outside via web or phone/tablet apps. H/W performance looks really decent. Again if you upload from internal with good wifi connections that's the key -> wifi speeds. e.g. can do abt 100+mbps upload speeds wifi but wired might go up to 200mbps
