Wooting One is the world’s first analog keyboard
ondooy
There are many different types of keyboards that are available. Rubber domes, buckling-springs, scissor-switches, mechanical switches, and more are out there for your choosing. However, they all have one thing in common. Every keyboard out there is digital, and one company is looking to change that.
When I say that keyboards are digital, you might be a little confused. Basically, there are two different types of input that a computer can receive: digital and analog. Digital devices transmit in binary. Every signal is either a 1 or a 0. Either you're pressing a key, or you're not pressing it. Pretty simple stuff.
Analog inputs can send a variable signal, which changes depending on how far or hard something is pressed. Think of the analog sticks on your Xbox or PlayStation controller. They're called that, because they transmit an analog signal, which changes based on how far in any direction you move it. Now imagine that sort of sensitivity on a keyboard switch. It would work something like the graphic below.
As the key is pressed, the signal transmitted changes. This is useful in games when you want to move one direction or another, but you want to have some control over the speed that you do so. If you want to slowly move forward, you might gently press the 'W' key, just the same as you would lightly nudge the stick on your controller forward.
Hmm.... sounds interesting, but no idea if its useful. Its quite hard to control how much you press on the keys. Maybe good for games where you have to control how fast you walk.
Elijahonli
hmm so what about typing? or need to install a driver now ? so that after certain amount of key travel, then register? but then again how isit going to switch back when in games :s22:
yusoffb01
We have something called controllers with trigger buttons and joystick
royfrosty
TBH, i think even if we were to ever need analogue control for gaming, one would choose a controller with analogue sticks and triggers to play it though.
But then again, if the games played are like FPS, that may need a mouse and a keyboards to run and shoot properly. This works well.
enenyi
So wad happens if we need to type? We need to press hard for a 'W' to show up properly in Microsoft Word? If we half-press the 'W' key, a faded 'W' will appear on screen? :s22:
royfrosty
Probably their drivers will do the job ba.
Like perhaps games they will run that analogue way. And when out of game, one has to fully depress the keys to register the key stroke.
