Huawei Mate 8 - The True Successor
jazzman80
seems like there isn't much discussion on this flagship.
the store should be selling today at $888, 4gb RAM & 64gb ROM model,with bundled smartwatch worth $128.
waiting to see how much is redwhite mobile selling.
marcus70
I checked, 808 but without the free be smart watch
benny888
Which version of Mate 8 can Hide Navigation Bar?
You can select hide the navigation bar by just dragging down the arrow down pointer on navigation bar. Select it to be on first at Settings/Smart assistance/Navigation Bar : drag the Navigation bar slide to the right. You will see an arrow down pointer at right of the navigation bar
gws898
I know, but which model supports it? Because I looked some forums, they said some versions doesn't support it.
rainbow99
thanks for sharing, tempting :)
Norman Chan
Are the casing and protective tampered glass selling already for this Mate 8 phone?
benny888
Maybe those users are ignorant of such a feature ??
Anyway you can easily check it up on 15 March when is launch at Spore
Mine is China set NXT-Al10
azarel
how much and what freebies?
sorry for late reply, i bought it at $888 (cannot bargain the $$ lower... instead i got the following freebies.. so maybe u can try)
- 2 x 32 gb microsd card
- huawei lifestyle watch
- 1 power bank 5000 mah
thoroughly enjoying the phone but i'm eagerly awaiting for a new case as i dun really fancy flip cases.
onoz__
Just bought one at itshow too.
$888 for phone and freebies:
-b0 smart band
-Wi-Fi router
-16gb usb otg
-64gb Kingston micro ad (normal slow version)
-water bottle
