Any idea where to find the key in the box to enter so that your trial period become permanent for 1 device ? it stated that i left with 13days of trial
I think what WTFast refers to is the free trial for premium service. WTFast premium service will downgrade to single device plan once the trial ended, and that the ac88u will continue to provide service for that particular client configured to optimise..
Using M1 1Gbps with the Asus AC 88.
Speedtest for xperia z5p= 100mbps,
note 3= 150mbps & apple 6=50mbps.
Test at ont 700mbps plus. What's wrong here?
Set your 5 ghz bandwidth to 80 mhz and channel to 48 or lower.
Why you set your channel 48?
Usually the higher channels can more easily susceptible to interference. Sometime lowering channels can see if this is case i.e. speed increase. 48 is roughly in the middle...good place to start.
Which Asus MU-MIMO router as access point good to pair with Asus RT-AC88U.
Ac88u or ac5300. Ac88u is a 4x4 router, no point getting 3x3 routers to bridge..
Ok, thank you. I thought ac5300 is a 4x4 heng ah, didn't buy it. I will go for AC88U then.
Hahas i think u read wrongly.. ac5300 is a 4x4. Ac3200 then is 3x3
Hi Guys, I would like to ask a question. It's possible if I set up my home network like that? Will my internet be affected?
ONT > Switch
Switch > RT88U > (Port 4) Mio Tv
Switch > RT87U > (Port 4) Mio TV
impossible.. someone asked the same question, or was that you?![]()
Hmmm haha it's not me. Then what if I want to watch Mio TV at my room and in the first level? My room is in the second level.
