M1 FIBRE BROADBAND DISCUSSION
kaireipy
How different, even like Dota you connect to different country servers the ip will be the same instead of changing Everyday. Unless you are connecting to private servers, ip also won't be changing Everyday, unless is illegal servers.
I play csgo and do tracert & most of the time get this
udp/ip : 45.121.185.207:27060
udp/ip : 103.28.54.168:27035
udp/ip : 45.121.184.139:27038
udp/ip : 103.28.55.78:27037
udp/ip : 103.28.54.139:27033
there are a lot of servers and I found that the servers are
103.28.54.0-103.28.54.255
103.28.55.0-103.28.55.255
103.10.124.0-103.10.124.255
10.156.7.0-10.156.7.255
jury_pack
Uh... Csgo... The IPs are under singtel and valve.
Sorry to tell you m1 doesn't have a straight route to SingTel, it goes a big loop then back. While value is in akamai I think? M1 has some connectivity issue to there.
jury_pack
Please share speedtest using SGIX or Softlayer. You can request tech to come down on site on Saturday. They can show you your speed and advice accordingly.
Did you even read? He don't have a laptop. M1 why will entertain? But 50+Mbps on iPad air 2 is normal.
kaireipy
sigh, no wonder, should have done my research before hand :/
XQuilet
Btw it not initial spike sorry for my wrong info given
did 2 speed test on iPad Air 2 I get 300+ to 400+ Mbps
And 2 speed test on iPhone 6 Plus I get 300+ to 400+ Mbps
There after drop back to lower speed again
Here u go
Tested on iPhone 6 Plus on RT AC56s
M1
Ping: 5ms
Download: 294.26Mbps
Upload: 212.29Mbps
SGIX
Ping: 5ms
Download: 131.47Mbps
Upload: 232.74Mbps
SoftLayer
Ping: 5ms
Download: 280.84Mbps
Upload: 210.09Mbps
Tested on iPhone 6 Plus on RE450 TP Link AC1750 repeater
M1
Ping: 8ms
Download: 168.93Mbps
Upload: 152.43Mbps
SGIX
Ping: 7ms
Download: 103.26Mbps
Upload: 171.47Mbps
SoftLayer
Ping: 8ms
Download: 163.05Mbps
Upload: 146.26Mbps
Anymore advise as of above stats or what I should ask m1 when they come down?
M1 is coming down on tue to see see
j_t_fusion
ac56 is not known to give amazing wifi speed.
what's more what do you expect from mobile devices with a wifi chipset the size of your fingernails.
XQuilet
Never want more of anything just checking on the speed as I dunno the standard that I should be getting. As I say m1 cs can tell u 40 Mbps is normal speed that is getting on iPad Air 2. So to be frank u think it normal as compare to what I hit now?
So need to compare n check den know the different mah rite
j_t_fusion
the problem with wifi is that there are a lot of environmental factors that will affect your wifi speed.
things like the number of wifi users in your neighborhood, any obstacle between your wifi router and your wifi device, the distance between your wifi router and your wifi device, the type of wifi router and wifi device you using, etc will all affect your wifi results.
and many of these factors have nothing to do with your ISP.
Henry Ng
Here u go
M1
Ping: 5ms
Upload: 212.29Mbps
SGIX
Ping: 5ms
Upload: 232.74Mbps
SoftLayer
Ping: 5ms
Upload: 210.09Mbps
M1
Ping: 8ms
Upload: 152.43Mbps
SGIX
Ping: 7ms
Upload: 171.47Mbps
SoftLayer
Ping: 8ms
Upload: 146.26Mbps
I think nothing wrong. For wifi there is speed limitation. For wifi on phone such speed is normal. Let M1 test out the speed with their notebook and explain it to you.
localITguy
Suspended
Here u go
M1
Ping: 5ms
Upload: 212.29Mbps
SGIX
Ping: 5ms
Upload: 232.74Mbps
SoftLayer
Ping: 5ms
Upload: 210.09Mbps
M1
Ping: 8ms
Upload: 152.43Mbps
SGIX
Ping: 7ms
Upload: 171.47Mbps
SoftLayer
Ping: 8ms
Upload: 146.26Mbps
believe it or not, your speeds are very good.
i get even worst speeds (AC88U)
lol.
is this 2.4 or 5Ghz?
lohsenglte
lol.
5GHz. 2.4GHz most of the time limit to around 40-60Mbps for handsets. Even laptops have problem getting >100Mbps since the interference is too strong, most of the time 45-70Mbps only.
Henry Ng
My old hand phone can only get 60 Mbps. For notebook I can get 110 Mbps for 2.4 wifi.
lohsenglte
Last time I can get 110 Mbps also but now dk why only 50 Mbps on laptop. Weird uh haha.
Question: Does M1 ONT have 4 output ports? Can I connect router to both port-1 and port-2?
M1 ONT have 4 LAN ports but only LAN1 is usable. Others all disabled deh. Why you need two routers though?
dazzleboy
My fibre point is at the door entrance cabinet and I have Ethernet cables to all rooms. Wifi will be weak if put router inside cabinet.
So seems like I will need 1 router and 2 AP now.
5star_pundit
just upgrade to M1 1Gbps fibre last week , can some one try swap the router now and see if it works ?
renfred89
your router can stay inside the cabinet with wireless turned off, then install 2 access points like what you said lor.. Even for singtel they only at most activate 2 LAN ports on ONT. One of router one for singtel tv only..
Henry Ng
I think is the number of sign ups during IT Show caused the capacity issue. The slowdowns are mainly during the night though. Hope M1 can resolve next week :/
Yes the slow down is during night time. Same for me. A few days ago I purchased internet security online so must download. I notice my dl speed as slow as adsl time, 2 Mbps only. Some M1 CSO like to keep saying it is the site slow and not M1 fault. Some time really vomit blood talking to some of them.
