Anyone Excited About Galaxy S7 & S7 Edge?
Executor 84
Alrite thanks, i think btr b safe then sorry. Will download it rite now.
Many more to explore. Seems theres more features compare to iphone n i love the camera, been shooting alot more then i use apple. Its very bright. Haha
Sent from Samsung Galaxy S7 Egde using GAGT
symbiote28
Looks like the Between app is the culprit?
between is my messaging app. no choice have to use. :o
another scenario, slept last night about 240am with battery at 74%. woke up and battery was 50% at about 11am. i did close all my apps.
wah drop so much?
deckcard
Testing battery life. Heavy usage throughout the day and got 8.5hrs sot
kryptonit3
wah drop so much?
it would be better if you do a wipe for ur device and start afresh.
Sent from Samsung SM-G935F using GAGT
symbiote28
if u think ur battery got problem, it's best to start afresh. format the device then do the settings and installation again.
what's the average you guys drop in battery % when sleeping? apps all off, wifi on, set to lowest possible screen brightness, 'always on display' on.
stupidog
erm i charge when i go to bed so it doesn't drop :D
maybe the first week u won't see any difference. perhaps after the 2nd week,
u will see how good is the battery as it's more optimized.
just remember try not to discharge ur battery till 0%
lithium battery cannot be discharge till 0% if not battery lifespan will shorten.
my phone last me more than 17 hrs on a single charge.
from 11am till i reached home 3am (heavy whatsapp, take photos, browse gagt and fb) still left with at least 20% power.
just take note of the apps u installed. some may not be ready / compatible for MM
for mine was rooted, so i frozed all the useless knox thingy, samsung extra apps.
i also turn off the battery % cos i wanna enjoy my gadget, not wanting to worry about the % drops.
my s7e is nearly 1 month old...so far so good.
