KouAnKyuuKa
- Nov 24, 2006
Just explain to your wife how important MM update is.
Updated to MM liao.
Everyday checking in Japan. Finally!
Updated to MM liao.Everyday checking in Japan. Finally!
haha just when we were ehem'ing them
just updated mine, no reset, seems ok.
Build date 7April, security patch "2 April2016"
edit: haha can disable Cable Fast Charging liao
Why u wanna disable leh?
Let the battery benchmarking begin!
Managed to get my MM update on 22/04. Happy with it so far!
Uh? I though if no use will just kick in?Ask u guys ah, doze kick in when your phone is lying down and stationary, but if my phone is vertical but stationary, will it still work?![]()
Took me 10 min to download. Depends on your bb or wifi speed.
anyone got call quality issues?
other party hear u soft then clear then soft then clear![]()
I see i see.Took me 10 min to download. Depends on your bb or wifi speed.
Took about 15 min to install. Depends on how many apps you have. The optimising apps for MM will take a while if you have a lots of apps bah.
Sent from Pluto using GAGT
