[BTO Nov 15] Punggol
GlitterBug
For waterfront 1, some lvl 2 has a higher ceiling. That's what I saw from the 3D model.
Sent from my glitter paws using GAGT
Gixxerfied
http://i.imgur.com/coWUCKtl.jpg[IMG]
[IMG]http://i.imgur.com/OUGicGel.jpg[IMG]
[URL="https://play.google.com/store/apps/details?id=com.shiportal.hwzreader&referrer=utm_source%3Dsignature%26utm_medium%3Dforum"]Sent from my glitter paws using GAGT[/URL][/QUOTE]
Higher ceiling at level 2 only..you wan?? :s13:
[img]http://i.imgur.com/a4QVE12h.jpg
Gixxerfied
So low only ?
Or might be higher at 2.5m..
Definitely not as high as those old flat..apparently inside source say I should get my keys in the next 1-2 weeks, once I get it I can do a measurement and then let u know..
windwaver
Gixxerfied
Use the site plan, blow it to 100%..Use the ruler then use the scale available on the site plan to measure..
About 40m gap..
kwgoh
Pray still got unit left.now 5 room last number called 501.still got 106 unit.last few days even those 2nd floor seaview unit got chosen.the inward facing nobody take.im ok with inward facing.
Sent from ahwee using GAGT
windwaver
How you know which is the last number called? Is that how you know the drop out rate too?
Espedine
For units beside plaza, won't it be very noisy during the day?
We chose right beside the plaza. Don't think it'll be that noisy since its just a food court and open space in front, noise will dissipate.... as compared to if you choose those unit facing inwards to other blocks then in the middle got playground or fitness area. The noise will echo upwards (current 11th floor flat like that, damn irritating even at night the cat fight also echo) But then again, how often you'll be home during day time? For us not so much.
kwgoh
Login to myhdb page.click to the page where it show your application status then click you reg number scroll to bottom will show called till number what
