Knight_Rider
- Apr 30, 2003
MR having outage now also.. Good luck to their customers getting any CS support..
Oh theirs can last a few days wan sibei scary.
anyone know what is the latest firmware version for zhone 2426?
my firmware is S3.1.208
viewqwest wants to update the fw but i am not sure whether the latest version will have issues
Mine is running on S3.0.610.
Using this version for a yr plus. So far no issue for me.
my version is S3.0.535 in the gpon 2426
May i know how to check the version?
type the IP address of your gpon and the zhone menu will show up. Then you click on Status and follow by Device Info. You will be able to see all its device information.
cheers
Arrr. I see. Thanks. i need to call VQ to get it. Mine is it bridge with my router. I calling![]()
Coincidentally I was a singnet user since the dial up until broadband, I made a switch to SH. Singnet = Zero customer service + Zero loyalty rewards at that time.
I still have my Starhub broadband for back up and because of the hub club privileges. Several encounters with SH technical team, most of the time requires me to do direct lan connection to pc and reboot router.
In comparison, I just send emails to NOC to get issues resolved if any. Been getting upgrade of bandwidth for the past 3-4 years, from 100mbps to 1gbps now. Still paying the same price.
Just hope things don't get worsened to SingNet & StarHub's stage, where they don't even give you a damn.
lol. I went through the same process as you. SingNet and then StarHub for years until VQ came along. The difference in CS is night and days between VQ and those two. I am happy to have alternatives to keep the big 3 in check.
Anyone knows how do I check if they are eligible for re-contract?
GoDSLaYeR wrote:
Anyone had Netflix throwing proxy and unblocker error?
Sent from Huawei NEXUS 6P using GAGT
Yes I get an error when I use the non-Freedom VPN DNS. Singapore netflix doesn't work for me (but US does when I use Freedom VPN)
We should try www.fast.com to see how VQ stacks up against other isps specifically for Netflix US streaming![]()
Yes I faced the same issue on Netflix. I do not have Freedom VPN on my service.
Anyway I tried Switching to 4G connection and the Video play right away without the error. The moment I switch to VQ the error appear.
But this is affecting some show only.
Yeah, known issue. VQ is working hard to make FVPN work for Netflix and Netflix is working hard to defeat FVPN…. so, its never ending.. cat and mouse
