Broadcom NetLink (TM) Gigabit Ethernet Configuration For 1GBPS
HelloHi
Hi,
I am currently on the 1GBPS fibre plan. Would need tips on the configuration of all the settings for my Broadcom NetLink (TM) Gigabit Ethernet adapter for the best output. Have provided the settings that needs to be configured below. Thanks in advance.
ARP Offload – Enable or Disable ?
Ethernet@WireSpeed – Enable or Disable ?
Flow Control – Disabled, Rx & Tx Enabled, Rx Enabled or Tx Enabled ?
Interrupt Moderation - Enable or Disable ?
Large Send Offload V2 (IPv4) - Enable or Disable ?
Large Send Offload V2 (IPv6) - Enable or Disable ?
Maximum Number of RSS Queues – RSS 1 Queue, RSS 2 Queues or RSS 4 Queues ?
NS Offload - Enable or Disable?
Priority & VLAN - Priority & VLAN Disabled, Priority & VLAN Enabled, Priority Enabled or VLAN Enabled ?
Receive Side Scaling - Enable or Disable ?
Speed & Duplex – Have set this to Auto Negotiation.
TCP/UDP Checksum Offload (IPv4) – Disabled, Rx & Tx Enabled, Rx Enabled or Tx Enabled ?
TCP/UDP Checksum Offload (IPv6) - Disabled, Rx & Tx Enabled, Rx Enabled or Tx Enabled ?
VLAN ID – What value should I set ?
Wake on Magic Packet - Enable or Disable ?
Wake on Pattern Match - Enable or Disable ?
WOL Speed – Have set this to Auto.
renfred89
Hi,
best performance will be the default ones.
ZrE0_Cha0s
i would say that u dun touch or change any default settings. unless u really knows whats the issues of the speed.
But may i first ask whats your ISP and the speed u have through the speed test.
Next make sure u are connecting via lan.
A few steps for you to make sure u have full speed (if possible):
Switch off router den next your ont. wait for 10 sec
Switch on ont wait for 10~15 sec den on your router. test the speed again.
HelloHi
Thanks for your replies both. Have already tweaked the settings previously so am not too sure what are the default settings. How do i reset the adapter? Anyways, i am getting around 600 mbps for download speed based on speedtest before and after tweaking.
ZrE0_Cha0s
try reinstall the driver and see. but may i ask is ur cable cat5e and quite long?
Mclairs83
1) What's your router model?
2) Your LAN cable how long? How old is it? Have u change a new one or a better quality one?
3) How many people connecting to the router?
4) Anybody downloading any huge files?
5) What's your operating system? XP is based on old tcp stack which cater for narrowband.
Apex
computer CPU and if there are any 3rd party firewall installed (Software like Anti virus and etc)
Those also affecting Speedtest performance.
HelloHi
Thanks all for your replies. My Cat 5e cable is kinda long actually. Have laid it from my hall to my room so i guess that could be 1 reason. Another reason could be because i am using Windows 10. Don't seem to find any new driver update for the adapters. Anyways, have already reset my adapter to its default settings and Starhub has advised that for a 1gbps plan, its good enough to hit 600+ mbps. Lol
HelloHi
Guess my antivirus might also be affecting the speed but don't intend to turn it off. My router model is DLINK DIR 868L.
ngbc
someone mentioned in M1 thread that setting power plan to "High Performance" improved the speedtest result :
86technie
If too long and not properly land the transmission may be affected.
If you want, you can contact a contractor to help you
setup a LAN point in your room.
Cost is about $1XX-$2XX varies on contractor and the distance
it need to cover.
http://www.income.com.sg/value-added-services/referral-services/home-services
HelloHi
Thanks for your replies. Have already set my power to high performance previously.
HelloHi
it need to cover.
Thanks dude. Will look into this.
Kiwi8
Deluxe Member
Recently bought a PCI-E Broadcom adapter to replace the Ethernet function that my onboard network adapter failed.
Seems good so far.
