royfrosty
- Jul 23, 2009
Introduction
MSI Twin Frozr, a cooler that has gone through many generations since 2008. Back then it was called the Hybrid Frozr, which fan blades will only start spinning when it hit a certain temperature threshold. It was then never used till lately the Twin Frozr V debut.
Some history back then...
Twin Frozr V has been a very successful cooler ever made in Twin Frozr history. This season, MSI has introduced the all new Twin Frozr VI cooler that has been strapped on with the GTX1080 and GTX1070.
So what are the real differences in between Twin Frozr V and VI?
The Twin Frozr VI has some minor improvements as compared to the older Twin Frozr V. The first thing you will noticed is the much larger cooler. It is about the same length, but however it is much broader than before.
The below pic actually shows the size difference between the GTX970 Golden Edition and the GTX1070 (below). Noticed the cooler and the shrouds? It is a lot larger than the Twin Frozr V.
Another difference would be the new Torx 2.0 fans. They did not increase the size of it, but what they actually did was they placed the fan blades much closer to each other. They have implemented dual ball bearing with the new fans.
That is all for the physical outlook of the cooler. More on what is inside later.
Unboxing
The MSI GTX1070 Gaming X packaging is no difference since a few gen back. It is a pretty standard affair, and there isn't a wao! factor when unboxing it. It is packed in a couple of layered card box.
The back shows the overall features of the GPU.
Removing the box, its the same accessories box with GPU under it.
But i'm kinda disappointed by the accessories they have provided. It is close to none. The accessories box is large, but there were only a product manual, a set of Twin Frozr VI stickers and a driver disc.
Unboxing
