Anyone Excited About Galaxy S7 & S7 Edge?
manualvin
yes did that already. same thing :s11:
What phone u using?
Just took a new pink gold s7 edge today and installed Samsungpay.
Works fine.
You can go to Samsungpay settings and reset app so that it's a fresh start
Even though the pink gold isn't for me as a guy, I must say it looks really nice! Wish list more colors for guys!
deckcard
re-enabled about almost all 'samsung' processes. guess time to try enabling everything again.
Here is my disabled.xml for package disabler pro that works for me. You can try and see if it works for u. Just import it but do your own backup first by exporting ur current setup
https://drive.google.com/file/d/0BxF_PtW_d8rKUDI2d1h0cEg5LTQ/view?usp=drivesdk
I tried it today at NTUC using pay wave and it works. I turn on nfc just in case
ecneret_eel
I too, missed the double tap to unlock feature from LG. But I found that I can activate the edge feed (by sliding down and up the edge of the screen) and if there are notifications, you can tap on it and unlock. Thus no need to press home or power button to unlock (i'my paranoid that they will wear out over time like my previous iphone experiences).
All these 3rd party double tap to unlock apps are more power consuming. Best to stick to built in apps.
I also use All in one gestures app to slide up from bottom to go to Home screen,so my home button is rarely used.
same.
double tap to wake simply rocks.
Sent from Samsung SM-T715Y using GAGT
approvois
Anyone using the batman apk experiencing very bad battery life during night sleep standby. Mine drop 30% overnight. Anyone have similar experience?
symbiote28
thanks. what i did was just update the samsung pay app via a 3rd party apk. now i'm having problems when i'm about to pay. i managed to link my cards with the app.
when tried with my fingerprint to 'pay', i get a error message "An error has occured. To identify the problem, an error report will be sent to Samsung Pay."
when i try the pin instead, the message "secure keypay is opening. Please wait." and it's loads damn long with no end.
deckcard
Bro why use 3rd party samsung pay? You should use from stock samsung
joesph
You need a proxy/vpn. You can setup vpn on another phone or PC then Hotspot it?
i bought expressvpn
win10 hotspot cant connect; off vpn can connect
iphone hotspot same thing
connect first then on vpn also cannot
